JVC AV28T77SK Intermittent fault
Discussion in 'General TV Discussions Forum' started by geoff1946, Jul 27, 2005.
  1. geoff1946
    geoff1946
    My mother owns a JVC AV28T77SK which is 1.5 years old.
    She reports that sometimes the normal picture disappears and a plain blue screen appears. She changes channel and the normal picture resumes.
    Any suggestions?
    Geoff
  2. GaryB
    GaryB
    Nov 12, 2002
    5,386
    St Albans
    +1,292
    The set will show a blue screen if the aerial signal goes missing.
    It could be an aerial problem or a fault in the tuner in the set. Go into the menu system and disable the "Blue Back". This will switch off the blue backgound and let you see exactly what the set is receiving whenit fails.
  3. geoff1946
    geoff1946
    Would you believe it? The SCART plugs were loose.
    Geoff
  4. geoff1946
    geoff1946
    Now the set has gone off completely???
    Geoff
