JVC AV28T25EK stuck on FULL VOLUME
Discussion in 'TVs' started by thurlon, May 23, 2005.
  1. thurlon
    thurlon
    Kids were watching TV when the screen went black - I changed channel via the remote and the picture reappeared but at full volume. The remote and rear volume controls do not do anything (on-screen level says zero, still belting out). Managed to switch the speakers off via the sound menu eventually.
    The kids said it 'clicked' before it all happened. I have been through all the menus I can find and nothing seems to work.
    Does this sound expensive?
  2. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
    See my answers on the thread below. It's possible that you have a variation on this fault. As your set is a T25 and not an R25, the Pro Logic & 3D Phonic options should be set appropriately for your model.
    http://www.avforums.com/forums/showthread.php?t=200936
    Make sure you read the whole thread first - and be careful.
  3. thurlon
    thurlon
    Many thanks...the procedure was slightly different, but close enough for a mere mortal such as myself to blunder through it.
    my children now believe me to be the DADDY! (which, of course I am.....)
    Thanks GaryB......I am, though, slightly scared that you know all this stuff! :smashin:
