Jvc Av28r25eks
Discussion in 'General TV Discussions Forum' started by Markt8, Apr 3, 2003.
  1. Markt8
    Markt8
    Does anyone know how to reset this tv back to factory settings?
    I was attempting to adjust the screen in the service menu and for sum reason the left hand side of the screen now moves in weird angles and makes menus look odd just on the left hand side.
    I am also getting an engineer out next week to sort out the tilt problem.
    Thanks guyz,
    Mark
  2. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Each tv should be set up individually so there won't be a 'factory setup' as such.
    Why didn't you write down the settings before mucking around ?
    A word of warning, don't disclose to the engineer that you've been in the service menu or your warranty *may* be invalid.
  3. Markt8
    Markt8
    Ah! I was seeing if i cud change the tilt in there and didnt mean to save anything :(:(, i didn't know at the time about this becoming a fault which cudnt be changed by the software.
    Can anyone give me a list of there paramters in the DEF menu of the service menu?
    Is it possible for the engineer to reset it if i meantion the left side being very odd?
    Thanx
  4. GaryB
    GaryB
    Nov 12, 2002
    5,387
    St Albans
    +1,294
    The DEF (deflection) settings are particular to your TV, so, as Lynx said, using the settings from another set won't work. There is no factory reset but if the engineer knows his stuff and has a pattern generator with them, they should be able to get it back to standard. By the way. there may be a limited amount of tilt adjustment available by rotating the scan coils.
