JVC AV24WT5EK help??
Discussion in 'General TV Discussions Forum' started by Wal, Aug 30, 2001.
  1. Wal
    Wal
    I purchased this set on Saturday got it home plugged the ps2 into av1 (RGB) socket but when I play GT3 the writing on the left and right edges of the screen are blurred the middle of the picture is fine it is just the sides I tried my dvd in this socket to and it does exactly the same for example when the player says it is loading the writing is blurry any help please???
