Jvc Av-32r25
Discussion in 'General TV Discussions Forum' started by preston, Mar 4, 2003.
  1. preston
    preston
    Feb 21, 2003
    138
    Preston
    I've finaly made the decision and I'm going for the JVC AV-32R25. For those of you not familiar it is JVCs 32" pure flat dolby pro-logic widescreen tv. Did well in the industry magazines. Anyone got any advice or comments. Any help with prices would be great. The best deal I can find is with Empire Direct at just under £700 including delivery.
  2. Doogy
    Doogy
    Mar 4, 2003
    17
    Southampton
    Gather it's had some really good reviews in Home Cinema Choice and a few other mags. Have recently bought the 28" model which has excellent pics/sound but..........I've been unfortunate to have a buzzing centre speaker (see other threads relating to this). However after a bit of shouting Debenhams are going to get me a new one ASAP. If it don't buzz and everything else is as good as my first one I'll be a happy bunny.........until I find something else to worry about! Am really impressed with the sound......ok it's only PL but for a one box solution it's ideal.I bought the matching rear speakers (they don't come with the set) for £45 inc delivery from JVC. I do believe there is a problem where AV1 (RGB I/P) suffers from darkened images but I use mine on AV3 S video which gives a great picture. Now.........are you going to take the plunge??????Something to consider........try John Lewis or Debs as they will price match and both give 5 yr guarantee.......they may also be more helpful if you have problems although you may have to raise your voice a bit at them!:smashin:
  3. preston
    preston
    Feb 21, 2003
    138
    Preston
    Sorry to hear about the buzzing, Doogy. As I have mentioned in another thread (JVC AV32R25EKS or AV32WFT1) a couple of friends have bought the 28" versions and they are very happy.
    I'm with you regarding the one box solution, it is ideal for my needs. I have run a couple of speaker wires prior to the carpet fitter arriving and I am now looking at buying the speakers. Mrs P is keen that I purchase a nice looking pair. I guess I've fallen into the life style camp. I was thinking about a couple of slim floorstanders and so I have dismissed the £45 JVC pair for now. To be honnest I don't know where to start looking.
    As for the RGB problem, I have resigned myself to using the S-Video connection but I will try RGB to see for myself prior to commiting.
    I have already ordered mine through Empire Direct (I know, I know but they were the cheapest) which came to just under £700 including delivery but no extended warenty. As far as I am aware John Lewis / Debs will only price match against shops on the high street and the cheapest I could find was £900.
