Jvc 37 Inch Lcd Confusion With Models?
Discussion in 'LCD & LED LCD TVs' started by dicko17, Jul 24, 2005.
  1. dicko17
    dicko17
    I'M REALLY INTERESTED IN THE 37" LCD'S THAT JVC ARE BRINGING OUT IN THE NEXT FEW WEEKS , BUT I'M A LITTLE CONFUSED IN WHICH ONE TO GO FORAND WHAT THE DIFFERENCE IS BETWEEN THE SETS.
    THERE ARE I THINK 2 MODELS THE LT37DS6 AND THE LT37DM6 , CAN ANYBODY TELL ME THE DIFFERENCE BETWEEN THE 2 MODELS AS I HAVE EMAILED JVC A NUMBER OF TIMES BUT THEY DON'T SEEM TO TAKE ANY NOTICE OF POSSIBLE FUTURE CUSTOMERS .
    ALSO WOULD I BE BETTER OFF WITH A PANASONIC 500 RANGE PLASMA THAN ONE OF THE ABOVE JVC'S ??? :lease:
  2. peahead
    peahead
    Dec 14, 2002
    2,847
    St.helens
    +285
  3. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
    The difference is that the DM6 includes a multi-memory card slot. This accepts SD, XD, Memory Stick/CF & Microdrives. It will play JPEGs and MPEG2 from the card slot. The DS6 is the same basic set but doesn't have the card slot.
  4. dicko17
    dicko17
    Thanks Gary , Have They The Same Response Time , And Have You Any Idea What Diamensions Are , I Have Around 1000mm Free Space To Place It In. Thanks.
  5. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
    The sets are identical apart from the memory slot. Response times are also identical.
    I've just measured the one I have here. It's 925mm wide, 110mm deep and the overall height (including the stand) is 690mm but I have a slightly different stand from the one normally supplied with the set so the overall height may be slightly different.
  6. MartinPerry
    MartinPerry
    You mentioned the sadly lacking JVC customer service, I too have had very poor service from JVC, they totally ignore new customers, this before you even buy the product.. whats it like after ?!, for this reason I totally discounted JVC and went to Philips... :eek:
  7. gazzer_67
    gazzer_67
    Jun 4, 2005
    224
    +13
    I read an article yesterday - published in an old TV Mag (Jan/Feb) that the DM would also have Full HD 1920m x 1080 resolution.
    Gazzer
