JVC 28" Question!
Discussion in 'General TV Discussions Forum' started by Grenaldo, Sep 5, 2004.
  1. Grenaldo
    Grenaldo
    Hi people,
    Need some Expert Advice here plz :D
    i have been advised that the JVC AV28X4 is a very good quality crt tv for around £400, it has a 'best buy' award from what video widescreen tv mag.
    My question is, what is the difference between this and another model i have found, the JVC AV-28X37. I can't see much difference between the two, and have found the 2nd for only £325 at:
    http://www.ajelectronics.co.uk/ViewProdDetails.asp?prod_code=PON20048131459
    However i cant see any reviews or opinions on this model, picture quality is the most important to me, but whichever i get must have a flat screen.
    If Anybody could advise me on which is the best, or what the difference is, i would very much appreciate it :lease:
    Thanks guys
    Stephen
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    X37 hmmm i think is an older model replaced by the X4 IIRC try www.jvc.co.uk for more info!
  3. GaryB
    GaryB
    Nov 12, 2002
    5,387
    St Albans
    +1,294
    Hornydragon is correct, the X4 is the replacement for the X37. The X4 does offer slightly better picture quality as it uses a newer generation processor as well as a few extra facilities such as picture/text mode. It also has a different cabinet - similar to the D40 IDTV but without the two-tone finish. As with most things in life, you pays your money, etc.
