Quantcast
JVC 26" LCD Wall Mount
ramtec
Does anyone know where I'd get a cheap wall bracket for this newly aquired beast? By cheap I mean sub £50.
Russ
HI,
I havent seen anything that cheap.
Unfortunatly this TV is quite heavy and will need something of substance.
The options I have found so far (Unicol, JVC and Vogels) are all 150 - 250 pounds.
The vogels EFW-1001 will support 15KG (5KG too little) but only costs 69.99
http://www.vogels.com/en/professional/frameset.asp?pid=pages/proddetail.asp?id=7331500
Unicol (www.unicol.com) might be a better option;
Apparently OK to 30KG
Basic LCD Wall Mount for VESA 75 & 100mm standard. *State VESA Size when ordering.
Order code: TWF175
Price Ex VAT: £45.20
OR
Basic LCD Wall Mount for non-VESA standard LCD panels.
*Please state make & model of LCD when ordering.
Order code: CWF
Price Ex VAT: £81.30 (Price can vary depending on make & model of screen)
Question is, is the JVC VESA compatible ?? I will check.
Also, what settings do you find best ??
Russ
Russ
ramtec
I don't think that those chaps at JVC know what there talking about! Indeed the holes are 120mm across x180mm....
GaryB
I think someone at JVC got their wires crossed. The 17" & forthcoming 23" are VESA, the 26" & 32" are not.
