JVC 17" widescreen on PC
Discussion in 'Plasma TVs Forum' started by Simon Pieman, Jun 11, 2004.
  1. Simon Pieman
    Simon Pieman
    Could someone please help me I have just bought a JVC 17E31. I am very happy with it but when i plug in my laptop the only resolution i can display is 1024 x 768 but the TV has a resolution of 1280 x 768....so the image is stretched. Is there a cure anyone!!! :lease: ...this is no good for the architectural work i'm trying to do.
    cheers
  2. GaryB
    GaryB
    Nov 12, 2002
    5,392
    St Albans
    +1,302
    The LT-17 is P&P so you should find that your computer will offer the correct resolution if you run the "Add New Hardware" wizard. Alternatively, use Powerstrip. This will let you set your resolution to anything you wish.
