JVC 16-gauge loudspeaker cable
Discussion in 'Home Cinema Speakers' started by Dr.Rock, Mar 4, 2002.
  1. Dr.Rock
    Dr.Rock
    Jan 10, 2002
    689
    London, UK.
    +35
    I found a reel of JVC 16-gauge loudspeaker cable around the house, sold at Dixons for about £15 for 16 metres (including 4 banana plugs and a cable-cutting tool). The cable is 2.5mm per core (79 strand, perhaps?)
    I just wondered, does anybody know if this cable good enough to utilise for my M7SD surround speakers (via Denon 2802 amp), or is it worth me paying up for better cable for my surrounds?
  2. mrblue
    mrblue
    Mar 2, 2002
    65
    Hi , I dont see why not , 2.5mm is a good size I am using QED
    which is 2.5 , ok its silver plated. still I would give it a try
    didn't cost you anything so you have nothing to loose!
