Juz,
Hear yor having problems with the picture quality on yor 737. I have to say I haven't seem anything like what you descibed on mine.
If there's a specific DVD you would like me to look at the I'd be happy to. The only help I can offer at the moment is the list of my setting as follows:-
YNR 0
CNR 0
MNR 0
BNR 0
Sharpness high MAX
Sharpness mid MAX
Detail MAX
White Level MID
Black Level MID
Black Setup 0IRE
Hue MID
Chroma Level MAX
Chroma Delay 3/4
The Chroma Delay gives a shadow/Ghosting effect around objects but is easily seen around the OSG's.
These settings give me an excellent picture on a 46" Toshiba WH08B. Hope this helps.
I use the component inputs as this gives a slightly stabler image than the RGB.
Regards Kev.
YNR 0
CNR 0
MNR 0
BNR 0
Sharpness high MAX
Sharpness mid MAX
Detail MAX
White Level MID
Black Level MID
Black Setup 0IRE
Hue MID
Chroma Level MAX
Chroma Delay 3/4
Regards Kev.
