Apologies for the inconvenience, but AVForums will be offline from 6am Thursday 21st January 2021 for a few hours while we perform a major update to our core software. See what changes are coming.
Nope , hard.
Have been able to get the Jan release re-installed using AID3 . Hopefully I still have the U/TDATA files I deleted in the Recyclebin .
Not sure where it went wrong though . Replaced the XBMC file with the new one , thought it would boot straight into it . Oh well
John
Have a look in the TCH3 read me file that comes with the latest builds it has all the info you need on installing XBMC as a dash.
I think the problem your having is that they've changed the shortcuts used to find XBMC as a dash
Team XBMC's shortcut tool.
It's included in the _tools folder as <<SHORTCUT by TEAM XBMC.xbe>> + <<SHORTCUT by TEAM XBMC.cfg>>.
Instructions here: http://manual.xboxmediacenter.de/wakka.php...upv2&v=1dmv
Rename the <<SHORTCUT by TEAM XBMC.xbe>>+.cfg & also EDIT the .cfg so it matches your config.
Upload to Xbox
