Just Some questions
Discussion in 'Plasma TVs Forum' started by Leerock, Jan 2, 2005.
  1. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    I ve been a member in this forum since last week.
    Before this I had no idea about anything regarding dvds and tvs.
    Thanks to you guys I ve learned a lot. :smashin:
    But I have some questions that i could not answer by searching in the forum.
    What s HDCP and what s scaler?
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    This site: http://www.digital-cp.com/ will tell you all you need to know about HDCP.
    A scaler will take an incoming video source and convert the output to match the resolution of the display device. i.e. it will take, for example, a PLA signal with 576 lines anc 'scale' it to fit the number of lines of the display device by either adding information if the display has a greater vertical resolution or removing information if there are fewer lines.
    Plasmas and LCD's come with scalers built in but an external scaler will yield better results.
    HTH
    John
  3. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    thanks a lot johndon :thumbsup:
