Just some advice please
Discussion in 'AV Receivers & Amplifiers' started by Mark306, Dec 24, 2001.
  1. Mark306
    Mark306
    Dec 8, 2001
    17
    I am thinking about buying a windscreen TV but I read somewhere on here it is not worth buying TV's with Dolby pro logic as this has been superseded by Dolby Digital. In which case I am thinking about buying a Nicam TV then buy a DVD player with Dolby Digital.
    I assume this will enable me to watch DVDs in DD but what about DD programs shown on normal Television, will they be played in DD? Also will the DVD player be backwards compatible with Dolby logic? I hope someone can shed some light on this for me.
    Thanks in Advance
    Mark
    Oh and Merry Christmas !!!! :p
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,744
    7
    2
    167
    Birmingham, UK
    +10,630
    Mark, if you read up a bit about the various sound formats in the FAQ here, you will learn some stuff.
    There are no 'normal programs' shown on 'normal' television in Dolby Digital. Suprisingly few are in Prologic, even.
    The only sources for Dolby Digital are DVD and a very few programs transmitted on Sky and received using a Sky+ box.
    When buying a TV, concentrate on picture quality. Nicam would be fine for sound. Then buy your DVD player. You can feed the stereo left+right output into your TV (as yes, all DVDs are prologic and stereo compatible) until....
    you buy a Dolby Digital amplifier, 5 speakers and a subwoofer.
    Then you feed the audio signals from the DVD player and your cable/sky box into that.
    Read some of the basic intro articles on the What Video site and the Total DVD site. Both of these have 'connection up' articles which should help clarify things.
  3. Mark306
    Mark306
    Dec 8, 2001
    17
    Thanks for the reply, the Total DVD sites seems to have loads of info, so i'll read that :)
  4. paiger
    paiger
    I was thinking of buying a windscreen TV but you can't get the wipers for them.
