Just setup new TH-37pw7 skin tones are all blue
Discussion in 'Plasma TVs Forum' started by Edmond22, Apr 18, 2005.
  1. Edmond22
    Edmond22
    Mar 21, 2005
    14
    4
    Edinburgh
    I just took delivery of my new panny today and have set up as follows.
    DVD panaconic DMR E55 to telewest pace box using scart lead put though a Denon AVR 1905 amp with component lead to sreen all other conecctions are component. Mangaed to get the DVD to play although all people look like the blue chick of Xmen. I have tried adjudting colour but nothing happens. Has anyone got any idea as to whats wrong?
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    could be component cables in wrong order?
  3. mr_incredible
    mr_incredible
    Sounds like it could be a video lead issue. Have you tried changing the lead? A good way to sort these things out is to strip your system down and try each one then by trial and error you should be able to indentify the problem. Start by running the DMR-E55 straight into the plasma with component, if it works fine then move on to the set top box etc etc. If you've done all that and its still the same it is a possibilty one of the items is faulty, it does happen! Let us know how you got on!
  4. mr_incredible
    mr_incredible
    Or like mep said which I forgot you could have the component leads in the wrong sockets?
  5. Edmond22
    Edmond22
    Mar 21, 2005
    14
    4
    Edinburgh
    Thanks folks I will give it a blast later unfortunatly work is calling. I let you know how I get on
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Is this component to the 'complete' video board, have you set the input on the plasma to 'component', not 'RGB'? Most likely is wrongly connected cables though.
  7. Edmond22
    Edmond22
    Mar 21, 2005
    14
    4
    Edinburgh
    Mr Inc tried what you said and PQ was fine. It would appear that the cable was knackered I swapped it for another and he presto. Thanks chaps.
  8. Edmond22
    Edmond22
    Mar 21, 2005
    14
    4
    Edinburgh
    Thanks Maw just saw your reply. Maw have you any idea why when I ordered a TH-37pw7b I got a
    TH-37pw7 any Idea what the diff is. As you can tell I`m new to this game. Have I ended up with an older prod?
  9. Steve_Whelan
    Steve_Whelan
    Sep 22, 2004
    118
    +3
    The B just means british stock (power leads etc) as far as i aware all Panasonic models have a regional suffix after the model nuber Eg. B British , DE, Germany. But apart from power leads and country specific warranty they are identicle.
