Just seen: Exit Wounds (Cinema)
Discussion in 'TV Show Forum' started by Reiner, Apr 9, 2001.
  1. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Ohje, I hear you say - another Steven Seagull movie.
    Yes, it's a no-brainer but quite some improvement (not difficult actually) over the former "The Patriot" and "Fire down below", at least he did away with that fancy dress.
    As usuall the story line is only used to connect the various action scenes including the compulsory group of youngsters trying to steal his car and getting bashed up, but it's not so bad after all and the story does have some twist towards the end.
    Should make good DVD material and for Seagal's fans definetely (sp?) a "must".
