R
rainstel
I've been having a few probs with me thomson DHD4000 pvr, with lockups, freezing when using the epg, remote has to be used 6" away from the unit, etc. I've solved all these probs by resetting the pvr back to factory defaults (software versh 1.7.7 from 2.2.3) and all is well again.......except for channel ITV2, where the picture is showing in 4:3 not 16:9. This is the only channel affected this way and I'm assuming its the reset thats done this. I've rescanned all the progs and manually set 16:9 in the setup but its still the same. Any ideas?
I'm gonna see what effect an update on sunday morning at 03:00 has first.
btw, is there a way I can disable these updates? they appear to cause more problems than they're supposed to fix.
Cheers.
Cheers.
