Just ordered an FQ80!??!
astonbilla
and im bricking myself. Has anyone seen or heard anything - i ordered hoping the new DRC will prove to be great.
I chose it over the philips 9617/9607 as i was not impressed by pixel plus. I think that DRC just nicks it, also the HUUGE Tosh ZD thread put me off that option also.
If and when i get i'll let you guys know, in the meantime....
....please pray for me!
mij
Hi astonbilla, I am getting refunded for my Sony, we both had a bad DX100, please let me know if it has scrolling bars and if the geometry is ok.
good luck
mij
mh66639
Spoke to Sony center today and they say the FS76 is in the country, and should be in-store next week.
I'll be checking for sb as well as purity, focus and geometry!
I'll post my findings is no one else has by then. I think the FQ80 and FS76 are the closest in the way of technology if not identical.
Matt.
dac
astonbilla,
remember me? ;)
after having a service engineer from the allders group services come by to inspect the tv, i have since been in touch with the stores tv department manager.
he's more than happy to replace my dx100 as it had crap geometry.
he suggested that i pop by the store and take another look again though, so as not to go through the exchange process again.
if i see an alternative tv i would rather prefer, he is willing to give me that option (any price difference will be refunded to me or me having to pay the top up)
i gotta say the digital broadcasts on my set was really clear though. and i would not go back to analogue :)
word is ... there's gonna be a new version of dx100 right? dx200 (saw it on indigo-av)
also ... a 36" version!
should i wait ... or just (fingers crossed) get a dx100 replacement.
cheers,
dac
p.s. good luck with the fq80 :)
MartinImber
KV36NX something - ie optical out for your AV amp!
M
MarkNordhoff
Hi There,
I got the FQ80 yesterday and I'm made up with it!!!! Definitely worth the wait. No Scrolling bars or other apparent probs!!! Apart from the weight of it, that is!!!:) :) :)
Enjoy your set when it arrives
Mark
astonbilla
What is the image quality like? better than the fq75?
M
MarkNordhoff
Yes the images quality looks great. Sony have also restyled the front, there are more curves rather than sharp corners.
A
alim
Glad to hear you can't see any SB on the new tv. I've ordered the 36NX200 which has the same design as the FQ80. By the way can you tell me if there are "holes" in the rear leg of the stand to allow cables to be threaded through? Or do you have to have them in full view.
M
MarkNordhoff
yes there are two 75mm holes in the leg (central at back) where you can thread all your cables thro and then there is a cover at the back of the set which encloses them all. The 75mm holes also have an adjustable cover, similar to an office desk. Once the DVD, video and sky are in place it looks really well!!!!
Nick23
Originally posted by MarkNordhoff
Hi There,
Mark
I went into my local Sony Centre yesterday and just stood stairing about 5inches from the FQ80 screen for about 5 minutes looking for the SB. I used to have a FQ75 so I know EXACTLY what to look for. Mark, did you have a FQ75, do you know what exactly you are looking for?
I just want to get as many comments on the FQ80's SB situation before I consider exchanging my TV for it.
M
MarkNordhoff
I have never actually seen a faulty FQ75 , but I have stared at this set and haven't seen any SB's. What is it you look for??:confused:
mh66639
One test is to put contrast/brightness up to 100% and put a DVD on pause. You could try cycling through the AV inputs too just to check each one.
Try putting a video recorder to the second SCART too, on pause.
So geometry is great and no purity (pick-patches) problems, what about focus?
Ta,
Matt.
astonbilla
Yeah actually, Whats the geometry and focus like - Also was the box sealed with Brown tape? or Sony Tape or Clear Tape etc....
astonbilla
My Wife just rang to tell me that the FQ80 has arrived at home. She noticed the delivery men had brought it in upside down!!!, and left it that way. When she asked why they said 'because the bottom of the box is open!'. I am now 100% ****ed off, when will i EVER get a TV without some sort of problem.
Surely the fact that its lying upside down in my house will affect the calibration of the screen, and why was the box opened?
I have no faith in this set already, i dont want it. I am going to send it back right away.
Nick23
At least try it out. Have a good play around with it, and see if the SB are present as I would really like to know from someone who knows what to look for.
astonbilla
So you want me to open the TV, unpack it, set it up in the living room and risk the chance of rejecting damaged goods just so i can chack the scrolling bars for you?
Very thoughtful
rct
Good idea... reject the goods immediately as second hand... you have no proof that it's new and some retailers are very fussy about giving refunds if you wait for too long.
Hope things work out for you.
mh66639
Astonbilla,
I'm sure Nick meant no harm!
Matt.
astonbilla
I know, Sorry - i'm just soo angry. Over the last 2 years this was my 9th TV, 7 of those were Sonys. 3 in the last month!
-Jay-
ASTONBILLA i`m not been funny but if you have had 7 sony tvs & not been happy with them.then why the hell have you not gone for another make because if i got a tv ie a tosh & it had a fault then i got another & that also had faults i would say stuff that & get another make why keep getting sony just to keep getting faulty ones witch seems to be p*ssing you off :confused:
mh66639
I bought a Tosh about 7yrs ago but exchanged it for a Sony due to quality reasons. Two years ago bought a FQ75 and I still think they are the best - quality-wise.
I hope to get a FS76 soon in exchange but did start to think about Panasonic. Other makes do seem to be catching up in terms of quality but Sony et.al. really need to ensure the small details such as menu-functions, purity etc. all work before they release a model.
My folks bought one of panasonics first wide-screens and it is for lack of a better word s**t. Only a few inches in the centre of the screen is in focus and lacks any type of quality.
I would still recommend Sony even after all the problems.
Matt.
astonbilla
Liverpool, why did you not change from Tosh to Philips when you had throuble with your 36" ZD?, its because you get used to the image quality from a TV.
Also, 2 of that 9 were Pannys
And when you get a good Sony, you really don't look elsewhere - i have just been unlucky.
Prey + Bullet Train reviews, Heat 4K + Event Horizon 4K and all the latest movies and TV news
Latest News
Movies Podcast: 8th August 2022
  • By Casimir Harlow
  • Published
AVForums Podcast: 8th August 2022
  • By Phil Hinton
  • Published
Warner Bros Discovery set to combine Discovery+ and HBO Max
  • By Ian Collen
  • Published
What's new on Sky, NOW and Paramount+ UK for September 2022
  • By Andy Bassett
  • Published
Pro-Ject Audio launches X2 B turntable
  • By Ian Collen
  • Published
