Luminated67
Can anyone recommend a motorised screen? I think ours is currently about 100 inches. Kids and wife now want a bigger one.
You need to work out where you are mounting the projector on the ceiling and then see measure from the middle of the mount to the screen wall, after you have this measurement take away roughly 300-330mm for half the length of the projector and the distance the screen material will be from the wall itself. Then use the link below to calculate the size of screen you can get.
Epson Home Cinema 5050UB Projection Calculator - Throw Distance and Screen Size
Find screen size and throw distance for the Epson Home Cinema 5050UB projector.
www.projectorcentral.com
For example a 120” 16:9 screen needs a minimum of 3.7m from the front of the projector to the screen.
