Just order SAMSUNG PS-50Q96HD.
ayubars
Hello Guys,
I just ordered this plasma screen from www.dixons.co.uk. Please tell me i have made the right decision. I may still be able to cancel the orfer in time.
thanks a million to everyone.
kbfern
This set will go loud without distorting but it does not sound very good.A bit boxy sounding(sort of enclosed sound, slightly muffled) not very natural sounding.
There are various sound modes available:music,speech,movies,custom but they don't improve things much in MY opinion,you MAY find the sound acceptable.
Personally I would recommend some sort of sound system to complement the tv.Do you have a decent stereo/hi-fi in the same room as the tv,if so run the tv through that, you will see a huge difference(depending on what stereo you have).
Sandy13
Established Member
Hi Sandy,
i understand you also have this TV. Tell me, have you had any sound problems with this set? I heard that the sound can be a bit distorted when you turn up the volume?
thanks
I haven't noticed any distortion at all, but I mostly listen via my sound system, as the sound from most TVs is usually very poor,:thumbsdow also, as I listen well into the small hours, I use headphones quite a lot:smashin:
ayubars
Hello,
Unfortunately i don't have any other sort of sound system. I did once have the panasonic cinema system but had to get rid of it as it was underused. Also freed up lot's of space in the living room. Maybe i will just wait and see. If it is normal sound like the usual TV's then good, i'll be happy with that.
Sandy13
Established Member
Re. the sound, as kbfern said, there are a few options in the sound menu you can try, and there's a possibility you could find one that suits, it's just that almost any system can improve on the inbuilt one supplied, that goes for most TV systems, but don't let that put you off buying this excellent set.:smashin:
kjt2004
Established Member
Suffering a last minute panick then
Dont worry just relax, yes it has shortcomings dont they all but bang for buck very hard to beat
Once its run in you will love it
Regards
ayubars
Thanks kjt2004.
I guess my only worry would now be the whopping 480W this beasts consumes. My older 44" projector consumes 225W so i'll have to be prepared for higher electricity bills :(
kjt2004
Established Member
I have routed mine so that the Tv(you know the type those 3 way individually surge mains plugs) is on one plug and the other devices are on another plug that way i can switch it off completely when not in use.
Regards
Mikeyd1963
Established Member
Mikeyd1963
Established Member
Hi these settings seem to be for the 97 are they as good on the 96.
Mike.
Sorry miss read the thread thourght it was about the ps-50p96.
Mike.
D
darkmagi
My wife bought me this tv for my xmas & i have no complaints, The picture is spot on & i think the sound is ok, Its not going to blow your socks of but its like the sounds system in my car, When i bought it it had a rubbish cd player & 4 small speakers, 6 months after i bought the car it has 12 speakers, 3 amps, a power cap & over 3000watts of power & im over £2k lighter in the pocket but the sound is amazing so it depends if you are happy letting the tv do the work or want to spend more money on a sound system, But as i said im happy with the sound that the tv puts out, Oh and by the way make sure you upgrade the firmware, The next download is next monday i think, You can go here to find out when it is going to be broadcast again.
http://www.dtg.org.uk/retailer/download_schedule.pl
Hope this helps........... :)
Samsung & LG UK TV Prices 2023; Amazon Fire TV Cube; Calibration Tools of the Trade + AV news
