voles
Established Member
Well I haven't had it 24 hours yet but I have some problems that the manual can't help with:
Can you reconfigure an input to a different remote button? The issue is that my Sky HD has coax audio, my TV has optical and the inputs are reversed name-wise on AV888. This was easy to fix on the AV9 but there is no obvious solution on the AV888. Am I stuck with pressing AV for SKy and Sat for TV in other words?
Zone 2 is in standby and grayed out in the menu. How do I bring it to life?
Can anyone help?
Apart from these initial niggles I am pleased with it. The auto setup was good at getting me going (despite putting the crossover at 40 hertz) and the result with a couple of small tweaks sounds very good. I will do it all again when everything is up and running.
Can anyone help?
