terrythecat
I've just received the RTC2200 I ordered from the states last week and installed
it between the Toshiba HD-XE1 and Barco 808s and have a little problem which
I hope someone would be able to help with. On standard DVD playback there is a mauve line which scrolls up continuously quite slowly and red, green and blue
dashes at the top of the screen which fade and then return and white dashes
which remain constantly. On HD there are numerous mauve lines about 10 inches apart which scroll up like crazy and white dashes at the top of the screen....no RGB dashes at top though. Should I be tweaking the 4 screws at back of the RTC2200....there are no instructions with the transcoder and I don't
want to fiddle until I know what i'm fiddling with. Also,the Toshiba is restricting
standard DVD playback to 576p....is this a firmware issue - I'm not sure what
the machine has come with. Cheers.
