Just had Sky + Installed Today
Discussion in 'Sky Digital TV Forum' started by connect, Nov 27, 2003.
  1. connect
    connect
    Aug 27, 2003
    682
    46
    +174
    I have just had Sky + installed today and must say I am very impressed with the service I was given. The Sky man turned up on time, put plastic sheets down so not to mess up the floor, installed very quickly and explained everything he was doing. Very impressed. Also it works well too!!
  2. wod
    wod
    Sep 7, 2003
    196
    +3
    at least you got a good installer, as theres a lot of muppets around fitting sky digital
  3. THFC
    THFC
    Feb 24, 2003
    242
    Gloucester
    +5
    Yehh - Installed mine today too.
    He had surgical boot covers on to not mess the laminate up in front room. Hammering it with rain too.
    Quality job, well impressed and a top bloke too
  4. caztime
    caztime
    do they take the old sky digi box away or is it yours.when you have sky =
  5. xyznicko
    xyznicko
    The existing digibox belongs to you after 12 months minimum subscription, they not entitled to take it away.
    The old LNB on the end of your dish which will be changed for a new quad LNB is also yours by right.
  6. caztime
    caztime
    THANKS xyznicko
  7. Loki101
    Loki101
    I am thinking of getting Sky+ also.
    What channels should I check are present to make sure the dish has been aligned correctly? I guess I want a small list of channels which I can tune to make sure it can receive ALL channels without actually checking that ALL channels are there!
    Thanks.
  8. MarkR
    MarkR
    May 3, 2003
    1,900
    Somewhere in Kent
    +344
    You will find that all most all of the Sky channels i.e Sky 1, Sky News etc. have the stonger signal. Channels like BBC1, ITV1, challenge TV, Men & Motors etc seem to broadcast on a weaker signal.
    Good way to test the signal is by going to the service menu which you get to by pushing services button followed by 4 and then 6. That will take you to the signal screen. As long as the two bars are above 50% and the lock indictor reads ok, in normal circumstances it should be OK. Hope this helps!!
  9. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,875
    3
    48
    +78
    I assume the dish doesn't need to be re-aligned for the new Sky+ LNB?
    And is the Digital Text very quick on BBCi?
  10. MarkR
    MarkR
    May 3, 2003
    1,900
    Somewhere in Kent
    +344
    No that is right your dish should not need aligning unless the installer thinks it may need it. All in all I have found that everything seems to run faster even though it still takes a little time to reach BBCi interactive screen but is still quicker to what it was. I take that is what you meant?
  11. gossp
    gossp
    Nov 5, 2002
    388
    Lincolnshire
    +7
    Well I had a right muppet come and install mine. Took him 1h30mins to set up ladders. then I had to help him haul a second ladder on the roof. He then after calling someone else to help took a total of 4hrs to upgrade my existing sky dish and box. He failed to plug the hole in the wall or tac down the phone cable (as was done in the previous installation). Can't be arsed to call them out again to tidy up, so finished it of myself. Terrible install though.
    I do love it. But find that its often very slow to react to my remote btn presses. The first day it was lightning fast, but now it can be irritatingly slow!
  12. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,875
    3
    48
    +78
    Yes,thanks.
    I wouldn't want my dish re-aligned as it is bang on anyway,thanks to a great Sky guy who had to correct the sub install.
  13. Tim_UK
    Tim_UK
    Aug 13, 2003
    34
    what's actually involved in the upgrade to sky+ ?
    Do they run a new cable from the LNB to the receiver - reason I ask is all my cables run under floorboards & through conduits and I would have to put in a new cable first as wouldn't want them messing everthing up !
  14. MarkR
    MarkR
    May 3, 2003
    1,900
    Somewhere in Kent
    +344
    Im afraid so. Your existing lead goes into the back and also a new lead is attached to the LNB to also go into the back of your box!!!
    Looks like you will be busy soon!!:mad:
  15. haf
    haf
    Hi all !
    Looking to get Sky+, but have cladding on side of building and cabling from dish requires to pass thru floor so they will not install as it is. I have an electrician doing work for me just now, if he runs the cable to the external wall for the dish, thru floor into lounge and into 2nd room (for mirror sub) will sky do the remaining work ie plug it in
    Henry:eek:
  16. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Yes they will, I put all mine in first as I wanted better quality coax and I wanted it out of sight. They just hooked it the LNB and the box and went of happy.
  17. haf
    haf
    Cheers Steve, I can rest easy then
    Henry:clap:
