Just had HD installed and needing some advice....
Discussion in 'Satellite TV, Sky TV & FreeSat' started by dasovic, Jan 5, 2007.
  1. dasovic
    dasovic
    HD has been set up to my Pioneer 436XDE. I have a couple of questions that I can't find answers for on the forums :-
    1. Should I set the HD box to 720; 1080 or automatic ?
    2. I have the box set up through the HDMI cable. It is also set up through the SCART. When I watch HD programmes through the HDMI they look excellent, however the non SD programmes (e.g. BBC1) look better (less red) and clearer when I watch them through the Scart lead. I was going to remove the Scart lead but can't really until I sort out the non HD HDMI picture. Have I set it up wrongly ?
    That's about it ! Thanks for any help.
  2. AV Junky
    AV Junky
    Oct 30, 2002
    1,215
    Staffordshire, UK
    +69
    1) Try them all and see which you prefer
    2) You have found what many others before you have also discovered - the Sky HD box is pretty average at de-interlacing SD material. The electronics in your plasma are better at doing this, which is why the picture looks better when viewed through the SCART
  3. SNICK
    SNICK
    Feb 4, 2001
    793
    28
    UK
    +29
    1. Try all 3 and see what works for you! Personally I have mine set to 1080i, others swear by automatic:rolleyes:
    2.Try component rather than scart - you may be amazed :D however for HD content best to stick with HDMI
    enjoy the new toy :hiya:
  4. huntere
    huntere
    Dec 30, 2004
    1,584
    63
    Perth, Australia
    +237
    I've used SCART, HDMI and component on exactly the same setup (see sig).
    My findings are:
    I use auto for HD output.
    For SD material yes SCART via RGB is marginally better than HDMI.
    Had a long spell on component (during the feared HDCP bug) and think HDMI is just better than component for HD.
    RGB SCART for SD is still better than component.
    BUT I basically use HDMI 100% now! More from convenience than anything else.
    As others have said, no right and wrong answer - have a play and use what you decide is best.
  5. athelstan
    athelstan
    May 23, 2006
    288
    Stowmarket
    +20
    I defy anyone to show me any difference in quality on HD pictures between component and HDMI. I have a high quality HDMI lead connected directly to the screen and a component going into the screen through a pioneer receiver. Is there something wrong with my eyes? I keep seeing people on here happily stating " Had a long spell on component (during the feared HDCP bug) and think HDMI is just better than component for HD" and the like and frankly I'm sceptical.
