joel88
Hi, from the advice of a couple people on here i bought an X1950pro from OCuk.
I uninstalled my 6600 and plugged the x1950 in. Nothing happened. Blank screen. So i tried it in the PCI-E x1 slot and it came on but after the first boot screen i just got a flashing underscore in the middle of the screen, this happened a couple times then it booted ok...only, everything was pink, no colours, only pink.
So after faffing around i could't get it any better, went back to the 6600 and it's all ok. SO, any ideas?
I'm using an A8N Sli-Deluxe board which is an Nvidia chip, would that be anything to do with it? As it's an ATI card? Or is it just faulty? I dont really want to use it if i have that stupid flashing underscore whilst booting.
Do you think i should just stick to an Nvidia card? If so, which is the best equivelant of the X1950. Sorry for the long post, you want to get this all sorted now and play Oblvion on full setting!!!
Help me out people!
Help me out people!
