Just got System Setup but I have questions
Discussion in 'AV Receivers & Amplifiers' started by danielod, Apr 13, 2003.
  1. danielod
    danielod
    I just Spent a wedge of cash on the system shown in my sig, I love the sound I am getting from it (i just need a decent TV to go with it now ... but will have to save for it). I just have a question when I am playing Dolby digital DVD's the Sony Amp displays "Dolby Digital 3 / 2.1" similarly when playing DTS enabled DVD's "DTS 3 / 2.1" is displayed on the panel.
    My worry is that the amp is getting sent a bad signal and just mixing up a 2.1 signal into some sort of mock surround output.
    Any help/advice/infomation gratefully recieved.
    Dan
  2. nathan_silly
    nathan_silly
    Nope working fine. Means Three discrete front channels, Two discrete rears channels, and One discrete bass channel (LFE)
    Next stop- 42" , at least. Or maybe a Sony G70 CRT PJ!
  3. danielod
    danielod
    Thanks for the quick reply, I am glad its working ok - although even if it wasnt it still sounds pretty damn good (i upgraded from a ps2/creative labs 5.1 speaker set) and its kicks that into the floor.
    For the tv I am currently looking either JVC or pansonic 32" (to replace chepo "beko" 28" 4:3)
    Dan
  4. nathan_silly
    nathan_silly
    Do a search on the model no's you're looking at- to get a idea if it's a turkey or not.
