Just got Rashomon from DDDHouse
Discussion in 'Movie Forum' started by bonzobanana, Jan 1, 2004.
  1. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,446
    Yeovil
    +219
    Stupidly I forget to check that it had english subtitles and it doesn't. Anywhere on the web I can download a script or subtitle file to use with the film. My understanding of chinese subtitles is poor to say the least. Are there any dvd playing programs that translate subtitles or any utils that will translate a subtitle file?
  2. joboy
    joboy
    Jun 10, 2003
    20
    UK
    The following web site specialise in Asian to English subtitles.
    http://subs.2ya.com/
    If you do a search for Rashomon you should find 2 sub title files.
    If you have a DVD burner you should be able to re-author your DVD with the English subtitles.
    The following site has a lot of helpful articles about working with sub titles.
    http://www.dvdrhelp.com/edit#20
    Hope this is of some help?!
    Joboy
    p.s. the subs.2ya site doesn't load properly on the Opera Internet Explorer (just in case you're using it), you need to use MS I.E.
  3. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,446
    Yeovil
    +219
    cheers for the info. Got the english subtitles. Having trouble converting them though as sami2sub util doesn't seem to work on my computer but I'm sure I'll get there eventually.
  4. Ger
    Ger
    Jun 9, 2003
    1,620
    Ireland
    +84
    I am trying to something similar with the French version of "All the mornings of the world", but can't find any English subtitles for it anywhere.
    Does anyone know where I might be able to get them?
