Just got new Nintaus n9868 - does everything player
Discussion in 'Blu-ray & DVD Players & Recorders' started by Crocodile JD, Mar 25, 2003.
  1. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    Hi All
    I've just got back from China where I picked up the latest Nintaus does everything DVD player the n9868. Actually I got the Chiese model, the n868. It looks like the VGA has been swapped for a scart on the European model!!! I'll stick with the VGA. It's got PAL/NTSC prog scan, Zoran 6 deinterlacing chip, Windows media WMA, DVD Audio, HDCD, 192/24 bit audio dacs etc etc...The only problem is that I don't speak (or read) Chinese so I'm struggling.
    While I was there my Chinese collegue translated the remote and set the menu to English for me, but I hadn't got the heart to ask for a translation of the complete manual. I was hoping to find an English translation on the net but no such luck.
    I don't expect many will have come across the Chinese model but as I mentioned, the European model is virtually identical. So if anyone knows anything about this player I could really use some help. Ideally I would like to get hold of the manual in English. I'll gladly stick a review up on the forum if I get that far.
    So far I've just hooked it up to by PC monitor and viewed a brief clip from Attack of the Clones and some promotional stuff that came with the player. It looks pin sharp on a small monitor. The test will be when I hook it up to my PJ (PLV30).
    My main concern at present is on the Audio. I'm not sure how to configure it. I don't want to send raw AC3 or DTS via analogue or do anything that might damage other equipment.
    TIA for any help
    Crocodile JD
  2. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    ....what about owners of the N9769, they're probably quite similar in set up terms??
    Crocodile JD :rolleyes:
  3. bxd
    bxd
    Oct 17, 2001
    1,482
    Southampton
    +136
    It's probable that somewhere there is an option to change the display language to english ........ I just haven't a clue what the chinese for 'English' is !
    Brian
  4. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    I think hes already done that, i think hes after a manual in english with some info on the player.
    BTW how much did it set you bac? If you don't mind me asking that is :D
    Spunky
    Edit: Just found this if its of any help http://www.nintaus.net/english/product/dvd/index.htm
  5. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    As you said Spunky
    I payed £70 for it. I've seen the European version on a Danish web site for around 2000DDK which roughly £200 I think. I've been on the Nintaus web site all it does is list the features impressive though they are, see below. It also has the new Zoran 6 chip, base management, VGA, Component, PAL/NTSC Prog Scan etc..
    Crocodile JD
    * Optional DVD-Audio function
    * Picture-CD function
    * Compatible with fashionable WMA format
    * System on One Chip
    * Progressive scan function
    * DTS decoder 5.1 channel output.
    * Dolby digital (AC-3) decoder, 5.1 channel _surround digital output
    * Compatible with DVD/ VCD/ SVCD/ CVD/ MP3/ CD/ CD-R
    * Free code
    * Multi languages
    _The audio soundtrack can be heared in up to 8 languages.
    _Subtitles may be displayed in one of a maximum of 32 languages.
    * Multi angles & Multi story
    * Digital audio optical output, 5.1 channel output, coaxial output, S-video _output
    * Parents lock setting
    _Parents lock setting to prevent play of discs unsuitable for children.
    * various KARAOKE _function
    * component output
    * 192kHz/24bits Audio DACs
    * Horizontal resolution >500 TV lines
    * Compatible with PAL/NTSC/ system
    * intelligent compensation and 6-level error concealment
