Just got my vdigi vga box for my xbox
Discussion in 'Xbox Forums' started by cyrusir, Oct 18, 2004.
  1. cyrusir
    cyrusir
    and its great, lovely picture on my samsung 213t tft.
    My only problem is, that to use the vga box i need to run the box in ntsc to enable the hi def options.
    Therefore none of my EA games will work, ie tiger 2005, ssx 3 and fight night 2004
    Is there any way to get them to work without an ntsc patch, and if not is there any where to get the ntsc patch without using bittorrent as im in work so a site would be great
    Also on some konami games the picture doesnt quite fill the screen using the vga box, theres a 1.5 inch border on each side? any idea how to fix that?
  2. rogeralpine
    rogeralpine
    Oct 28, 2002
    573
    16
    ...looking at getting one of these boxes - is it a true VGA signal? I know some of the early one's on the market had some kind of "forced" VGA that wasn't the real deal.
  3. cyrusir
    cyrusir
    no this thing is the business, as good as the x2vga box but works for all consoles
