Just got my sky+ today but.....
Discussion in 'Sky Digital TV Forum' started by tuono, Sep 21, 2004.
  1. tuono
    tuono
    Sep 3, 2004
    47
    anyone else had any problems with the digital sound output? (analogue is fine)
    Mine doesn't seem to work :confused:
    I don't think it's an AV problem (I simply unplugged the tos link from my DVD player which was working fine, plugged it in.......nada
    I've changed the sky box setting ie: sound settings > Dolby Digital
    The station WAS transmitting DD
    Can't think of anything else
    Sky are sending an engineer Thur to check if optical output is OK but can anyone else suggest anything :lease:
  2. Pug72
    Pug72
    May 10, 2003
    2,096
    Hereford
    +313
    I presume you saved the settings after changing to DD?
  3. tuono
    tuono
    Sep 3, 2004
    47
    YES :) (but thanks for the suggestion!)
  4. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    By station you mean one of the SKY movie channels AND while it was showing a film with a DD soundtrack ?
    Didn't you get any audio at all or just no DD?
  5. tuono
    tuono
    Sep 3, 2004
    47
    Yes AND
    Yes...........Sky+ 'helpline' also helped confirm this
    No DD, analogue is fine :confused:
  6. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Well if you don't get even stereo via the optical output it certainly sounds like a hardware issue since you say both the cable and amp work when plugged into a DVD player.
