Just got my Philips 36'' 9607 P+
Discussion in 'General TV Discussions Forum' started by Dan110, Dec 14, 2002.
  1. Dan110
    Dan110
    First impression very good, however after a few hours a few niggly problems.
    1. Vertical geometry is pretty bad, buildings lampposts and any vertical straight lines are a bit wonky!
    2. On very white scenes, slight red staining on both sides of the screen.
    Other than that, pretty happy. Can the vertical geometry be adjusted to straighten out the lines? Is it correct that I now have 7 days to return the item if i'm not entirely happy with it?
  2. ryanos
    ryanos
    Nov 17, 2002
    266
    +3
    The seven day rule applies if you bought the set online or by mail order under the distance selling regulation so if you bought your set by either of these means then you will be able to send it back. I had the pixel+ 9527 and thought it was poor so i sent mine back;)
  3. SHELEN 61
    SHELEN 61
    Got my Phillips 36" pixel + a week ago along with the Panasonic XV 10 dvd , XR 10 receiver & HE 9 speaker kit and sub..............
    ALL I CAN SAY IS THIS IS THE MOST AMAZING AND INCREDIBLE TV , DVD AND SURROUND I HAVE SEEN AND HEARD ......... £2,500 AND WORTH EVERY SINGLE PENNY ......... :D :)
  4. Dan110
    Dan110
    Does the 7 day return policy apply if I purchased the TV from Currys?
  5. ryanos
    ryanos
    Nov 17, 2002
    266
    +3
    yes it should apply to all retailers
  6. cdave
    cdave
    Dec 10, 2002
    306
    The 7 day rule is useful and it is easier to return within that time, however, the set must be fit for the puprose and of satisfactory quality, free from minor defects. If you find yourself outside of the 7 day rule because you did not spot something or it occured later then you are still covered by the sale of goods act 1974. The sooner the better though
    Dave
