Just got my Panny PW5 - Amazing!
Discussion in 'Plasma TVs Forum' started by Claus, Jan 31, 2003.
  1. Claus
    Claus
    Hi!
    Gor my Panny PW5 yesterday and the picture is stunning!!!
    I'm running a Primare V25 DVD player with progressive component
    output both in NTSC and PAL. Those PAL progressive signals are impressive!
    Got a couple of questions...
    -Is there any rotation of the picture to avoid burn-in(can't find it..?)
    -Should I turn the 3:2 pulldown on?
    -Should I turn Screensaver to on?
    -Should White Balanse be set to : Normal?
    Thanks!
    Claus
  2. Jackass
    Jackass
    Jan 9, 2003
    3,395
    +807
    Enjoy your plasma Claus!
    I love mine and have a Panny Progressive XP50 DVD player winging it's way from the States.
    Regarding 3:2 ,
    Don't quote me but I think if your dvd player is already doing progressive for NTSC then you don't need it on in the panel although i might be wrong.
    I don't bother with the screensaver
    White Balance: Depends if you like the picture or not.
    Steve.
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,039
    Claus: As has been stated. If your DVD has 2:3 detection then it doesn;t matter. If you have a VCR attached and watch NTSC Video tapes then stick it to on. If you are in an NTSC broadcast country then stick it to on.
    White balance: High is NUTS too blue
    Normal is still too hot (blue)
    Low it too red (cold)
    Low is closest to correct but you will probably prefer Normal. I am sure you would prefer correct though;)
    Gordon
  4. gileso
    gileso
    There is a 'wobble' feature on the extended setup menu (press "setup", highlight "OSD language", press & hold "surround"). This, I think, is the rotation setting. Although when used on mine, it just seems to creep the picture in a single direction....
