Just got my new Denon 550 and need some help
Discussion in 'Home Cinema Buying & Building' started by mark raeburn, Apr 5, 2005.
  1. mark raeburn
    mark raeburn
    Nov 14, 2002
    413
    +19
    Set it up (after a couple of hours) and am very impressed with the sound however not very impressed with the DVD PQ.
    I have it connected to my Panny PW5B plasma, and selected prog component on DVD. The picture shows slight pixilation on murky backgrounds, also is grainy and has significant shimmering on for example grilles of cars. I had a Sony NS 730 progressive component and the pic qulity on this was far better - no pixelation/graininess or shimering. Am I doing somethin wrong with the settings?
    Also the cable provided to connect the amp to the sub is not long enough - can I just replace this with any old longer phono cable?
    Cheers for your help.
  2. Paul Philpott
    Paul Philpott
    Mar 13, 2005
    459
    Newhaven
    +58
    How have you connected the DVD to the plasma? You can use a longer good quality lead for the amp-sub connection. Out of interest what speaker settings have you used??
  3. mark raeburn
    mark raeburn
    Nov 14, 2002
    413
    +19
    Have set speakers to small.
    So I can just use a good quality phono cable for the sub then?
  4. Paul Philpott
    Paul Philpott
    Mar 13, 2005
    459
    Newhaven
    +58
    Yes that lead should be fine-re your problem how is it set up??
  5. mark raeburn
    mark raeburn
    Nov 14, 2002
    413
    +19
    cheers
    Picture is no better - still seeing graininess and pixellation. Also find the menu extremely slow i.e when you click to play, it seems to take an age to move from the menu screen to playing th movie.
  6. Paul Philpott
    Paul Philpott
    Mar 13, 2005
    459
    Newhaven
    +58
    How is your 550 connected to the plasma??
