just got a lg26lx2r
Discussion in 'LCD & LED LCD TVs Forum' started by knobbs, Sep 19, 2005.
Tags:
  1. knobbs
    knobbs
    hi just got this panel today, not overly impressed. one prob which was weird, i put the scart in from my sky box in to av1 which is rgb, and the picture was very very dark, dont think its a setting prob as there isnt anything to change.
    is it possible theres a fault with this set.
    cheers knobbs.,
  2. peahead
    peahead
    Dec 14, 2002
    2,992
    St.helens
    +383
  3. knobbs
    knobbs
    hi phoned lg they said sounds like a fault with the panel.
    so where do i stand with the retailer can i demand a full refund.
    ive got a 7 day returns gtee, b cause i bought it on the web.
    but they said theyl charge me 35 squid for picking it up and il lose the 15 squid i paid for delivery.
  4. peahead
    peahead
    Dec 14, 2002
    2,992
    St.helens
    +383
    Hi knobbs
    If the tv is faulty then they should ither refund you the cost of it or replace it at no cost to you did you tell them it was faulty and is it comet you got it from.
  5. knobbs
    knobbs
    hi phoned them television and video direct and they said they would pick it up tomorrow and check it.
    my word against theres i suppose.
  6. knobbs
    knobbs
    hi i tried to upload some jpg pics of the panel, it says file too big, anyway round this, cheers knobbs.
  7. peahead
    peahead
    Dec 14, 2002
    2,992
    St.helens
    +383
  8. knobbs
    knobbs
    hi peahead uploaded image on the link u gave me, it leaves you with 3 links, how do i put the image on to this forum cheers.
  9. peahead
    peahead
    Dec 14, 2002
    2,992
    St.helens
    +383
    just copy and past the link into the thread.
  10. knobbs
    knobbs
  11. knobbs
    knobbs
    hi thats the panel with the contrast on 50, brightness 50, colour 40.
    cheers knobbs.
  12. peahead
    peahead
    Dec 14, 2002
    2,992
    St.helens
    +383
    Have you tryed turning the auto Eye Intellegent picture setting of to see if this helps and does it have backlight adjustment.
  13. knobbs
    knobbs
  14. knobbs
    knobbs
    hi ive got a lg rz50 its 20.5 inch model paid 700 squid with the gtee for 3 yrs, heres a pic, from around 6ft above away pic is great, footys brilliant no motion or pitch blur.
    its not even got rgb, i tried the lx2r on av2 it all brightens up like the other lg, but the artefacts are all there to see, footys a http://img54.imageshack.us/my.php?image=dinroomlg4iz.jpg
  15. knobbs
    knobbs
    hi i think the lg26lx2r is a good panel, think i got a bad one, but its not for a small room, u need to be at a good distance to view this panel.
    even with my other lg u need to be at a distance to benfit the great pic.
    i like my tv pics to be bright, full of colour, no artefacts on the footy-or gee gees, maybe i have me telly settings too bright for some, but every one too there own.
