Just finished Hushbox for PLV30.
Discussion in 'Projectors, Screens & Video Processors' started by Ricky27, Jul 26, 2003.
  1. Ricky27
    Ricky27
    Feb 8, 2002
    1,701
    Norwich
    +144
    I made it from 15mm MDF and it turned out very neat and tidy, although i planned it all out on paper and got the measurments spot on, measure twice cut once etc.
    I simply cut out a hole for the lens, another in the bottom for the intake fan in the bottom of the PJ, one at the back for leads and a little more air flow, and another hole onto which i bolted a quiet 80mm PC case fan which sits in front of the main exhaust fan on the PJ.
    The lid sits inside the top on batons and i have to say it works a real treat, cuts down the noise by alot, its now more a hum than a hurricane.
  2. upallnight
    upallnight
    Jun 11, 2003
    1,674
    48
    watford
    +58
    sounds good ,any chance of any pics?
