Just Did it!!
Discussion in 'Projectors, Screens & Video Processors' started by hansrob9, Jan 6, 2005.
  1. hansrob9
    hansrob9
    I just ordered my panasonic ae700 from 123 Electricals. 1229.99 including Saturday delivery. So I should get this in a couple of days... :clap:
    So now I am going to be able to concentrate on getting some decent sources to feed it. My old lecson dvd is getting decommissioned...
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Silly boy. :devil:
    Now the upgrade cycle begins. ;)
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Nice one. :smashin:
    Now then. Bracket/shelf, screen, cables, conduit, new DVD player, more cables, HTPC, new amp, sub, speakers, more cables...
    if you're lucky you may even get a chance to watch a few DVD's!
    :devil: ...PJ
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    What a damned strange thing to want to do with an HTPC-based system, surely twiddle FFDSHOW is what it's all about? :p
  5. hansrob9
    hansrob9
    Isn't that the beauty of it ? ;-)
    So far on my standard TV I have managed to watch 2-4 DVD a week, I am planning to continue on the same trend...
    Now, where do I get a good screen for this baby?
  6. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    :rotfl:
    Not gone the HTPC route yet, don't see me having the time to sort it, especially as I have to spend so much time on this forum now... ;)
    ...PJ
  7. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Fixed - make one yourself (MDF) and save yourself a lot of money, then paint it with screen goo and spend all the money you saved ;)
    Pull down - cheapo route - buy a blind, proper route - lots of options but not cheap!
    Lots of other variations, blackout material stretched over a frame seems popular.
    Told your other half yet that you won't be spending much time with her in the forseeable future? ;) ...PJ
    PS separate forum on projector screens v. useful!
  8. peter123
    peter123
    not bad but you could have saved 30£ by ordering from godigital
    cheers
  9. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,411
    Surrey. UK.
    +2,083
    I went the frame and blackout cloth route, then later upgraded the material to some Ellie 1.2 gain stuff. The BO cloth and frame cost under £30 all in, but proper screen material can cost £50 and up. In my case it was a small improvment, which to my mind makes the BO cloth hard to beat for value/performance. Pics on my website if you're interested.
    As PJTX100 mentioned, there are many ways of making you're own screen, and painting a wall with three good coats of matt white paint is probably the cheapest, and will give you something not much different to a plain white screen.
    Gary.
  10. hansrob9
    hansrob9
    Thanks guys. I am going to start with some home made cheapo (some white sheets) so I can gauge the image size I'll be confortable with.
    After that I have *very* tempted by the electric screen route. I know that's expensive, but that looks pretty cool as well ;-)
    Anyway, that's for another time (and forum) so for now, I am going to quietly wait for the delivery man (where the f*** is he :suicide: ?)
  11. 3wrLcs
    3wrLcs
    Jan 12, 2003
    33
    I did it as well today, should get it tomorrow, paid £1300 with £100 of other items which will probably be a screen once I've decided on the size.
    Brendan
  12. hansrob9
    hansrob9
    Well done. That was my initial plan but didn't manage to put the order before the deadline, so had to revert to the £30 extra to get it on saturday.
    What screen are you going to project on?
  13. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    I have been trying every 'home made' screen option this last week as I sold my Grandview electric screen on here in the summer. What a costly mistake! :mad:
    My evaluation so far.
    1. Roller blind. Awful. To thin. You can see all of the fleks in the material unless you buy a dearer blind. Where though ? - imo most blinds are equal.
    2. Black out material. Closer to fibre glass type screen material but not enough gain in the material in my opinion. can create a noisy picture.
    3. Plain, smooth plasterboard wall painted with three odd coats of white paint. Very very good. Appears to have far more gain than the black out blind. I am going with this at the mo as the black level on my PJ is FANTASTIC! May test ice storm at some point.
    I had a roll of screen flock delivered today so I will cut that to size over the weekend and make a nice velvet look border.
    Hope this helps.
    PS, refer to the screen forum. Zombie Donkey has an excellent example of a home made MDF screen :smashin:
    Cap :)
  14. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,411
    Surrey. UK.
    +2,083
    Black level is another area where the Ht1000 excells - especialy with the iris shut. Add the Hoya FL-Day, and it takes another step in the black level. :)
    Gary.
  15. hansrob9
    hansrob9
    I received the 700 on saturday morning :clap: and as all would expect, I immediatly spent some time setting it up. I have the benefit of being able to black out completely my front room, so daylight wasn't an issue. A white sheet was quickly setup, DVD player hooked up the projector, and... wow!! This was the childhood dream of having my own cinema come true.
    Obviously, I need a screen, which is what I am going to do next, and a new DVD player, as mine is actually more noisy than the projector !! :suicide:
    One of the thing I really like about the 700 is the x2 zoom. This is really a killer feature for anyone getting into home projection as image size can be adjusted a lot, projector position in the room is very flexible and allows testing various image sizes, etc... I can't comment on relative picture quality with the other projectors but to me this zoom makes the difference.
  16. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,770
    167
    The Wheldon Road end!
    +7,938
    I went down the wooden frame & blackout material path and the results are great. I can't compare it to anything apart from shining it on a wall (which it beats hands down) but i'm very happy with the picture I get on it from my Epson TW10H. The wood cost around £5, the material about £7 and the paint (Blackboard paint for the border) around £5. I also needed a staple gun which cost another £5. So for £17 (cost of materials, excluding tools like staple gun) this is great quality for what you pay! I could actually do with making a 7" one though as the picture only just fits on my 6" screen with minimum zoom as it is! :thumbsup:. The beauty of PJ's is that all I have to do is build a bigger screen and as I have a load of wood left, this should only cost me around £10! Not bad for getting another ft on your picture!
