Just bought xbox hd cable need a bit of help.
Discussion in 'Xbox Forums' started by EVOII, Aug 25, 2004.
  1. EVOII
    EVOII
    May 4, 2003
    Hi guys,
    Ok i have just recieved my microsoft hd cable for my xbox, and have just realised that that the cable is component and my 42" RPTV only has 3 scart inputs and no component :(
    Anyway is there a way which i can connect my xbox to my tv using the microsoft hd cable? (component to scart)
    Thanks Dave :)
  2. Rob20
    Rob20
    Jul 3, 2004
    3,188
    +722
    Surely if you're tv doesn't have a component input, it also would be able to receive a prog scan signal. Therefore you might as well just use an RGB cable for all the hassle of converting a component signal into an rgb signal.
  3. EVOII
    EVOII
    May 4, 2003
    Thanks for your reply Rob.
    I'm sorry i am new to all this, my tv is deifinetly progressive scan.
    How do i know if my tv is HD?
  4. bossc@
    [email protected]
    Dec 20, 2001
    1,164
    +273
    You only get Prog Scan through either component or VGA - what model tv is it?
    And is your box modded?
    Just had a search on your TV and I can't find any reference to prog scan - only 100 hz!
  5. EVOII
    EVOII
    May 4, 2003
  6. museumsteve
    museumsteve
    Jan 28, 2001
    7,980
    4
    Nth Hampshire
    +1,094
  7. EVOII
    EVOII
    May 4, 2003
    I'm sorry the UK version of this tv does not have component inputs :(
    LOL I think i'm a bit stuffed.
  8. EVOII
    EVOII
    May 4, 2003
  9. EVOII
    EVOII
    May 4, 2003
    Anyone wanna buy a Microsoft HD cable LOL
  10. Pooon
    Pooon
    Dec 26, 2002
    7,397
    Canterbury, Kent
    +989
    I'll swap my un-modded PAL xbox for your modded xbox and hd cable!!!!! lol
  11. EVOII
    EVOII
    May 4, 2003
    Nah i will just have to buy a new TV !!!
    LOL
