Just bought the Samsung LE40R87BDX - have I made a good decision?
MrMav11
Hi I took the plunge after the Sony 40S2530 went up in price (is the LE40R87BD a match for this Sony?) and ordered a Samsung LE40R87BDX!!
My budget was (as cheap as I could!! ;) about £850 for the TV, I also ordered a Piano Black glass and chrome stand that I had seen which looked cool in Comet and Dixons, all came in under £1000
I was torn between getting the older Sammy LE40R74 it was about in total £200 cheaper, so my question is was an extra £218 I paid worth it for the newer Samsung model, and a 3 year warranty over the 1 year I would have got with the R74?
Does the gaming mode work for Xbox 360 gaming in these or is it a gimmick.
thanks
Any comments please?
MrMav11
ha ha ha yeh I guess your right!! :)
I would just love to hear from other people on this TV thats all, there's no info or reviews on the net about it, thats why I was nervous about getting this one
In your opinion though about the extr £218 for a 3 year and a newer generation what you think?
sTaD
Established Member
I've just brought one of these. Had it about 2months now....got my pc hooked upto it and on plain backgrounds its flickers a bit. :(
MrMav11
are you sure its the new R87 range and not the older R72/R73/R74 range?
The R87/R88 have just been released this month.
Can you confirm the model please, is it only on PC use you get this? what about TV watchin gplease?
cheers
M
Mells1975
Hey andyloc,
how would you rate the tv as a whole? any negatives?
have you tried the set with a pc yet?
i'm thinking of the 32.....
thanks
MrMav11
Just waiting now for it to come, Depending on when it lands, Itt'll prob be tomorrow when its all setup, I will take sone pics etc if anyone is interested.
I will be connecting to my PC as well, but will have to buy the cables etc 1st
r7, just found out i never setup pc right for it:rotfl:
So the R7 you have, whats it like? Im hoping that the R8 has ironed out any probs tht the R7 has had, I paid extra to get the R8 over the R7 so hope its worth it!!
MrMav11
guess what its not coming today surprise they phoned and said lorry broke, next week now Im absolutely fuming
sTaD
Established Member
its good mate...just a few tweeks i need to be honest.
Not sure if its the TV itself or the setup. White background flickers sometimes.
MrMav11
well it didnt turn up "the lorry broke" was there excuse.
Told Mon now, not holding out for it coming though,wil get back here with pics etc when I do
cheers
bignige
Established Member
Picked one up today, price matched at Currys. I couldn't fault Currys, they had no idea what I was on about with regards to the panel, but let me check & I got myself a S-PVA! Very helpful lady & manager. Was told I could bring it back if it wasn't the right panel! (Coventry).
I've not started tweaking it yet, but so far I'm impressed. VGA seems a little washed out with Xbox 360, but then it did on my previous Samsung.
MrMav11
How much did you end up paying then please? Are you not going to use your 360 using component? thats what I was planning with the stock cable.
Also have you tried the gaming mode? whats it like?
Hen you say you checked your panel 1st, was the 1st one you come to a S-PVA? do you think that was luck or ost likely all the 40" will be S-PVA?
bignige
Established Member
I've always used VGA with 360. I like the slightly subdued picture. I sarted a thread for owners to share settings and problems.
http://www.avforums.com/forums/showthread.php?t=512667
Currys price matched their website so got it for £849.99, instore price was £999.99
Not really tried game mode, it seemed to make the picture over component quite dull, to be honest I've not really explored the settings too much. I'm letting it settle in for a bit first.
MrMav11
Is this a norm? ie a LCD needs time on displaying pictures for the panel to "run in" ?
Empire Direct have it for £780 now you know? or did you want to pick it up? (you must have a huge car!!)
I will look at that link when I get mine
bignige
Established Member
I wasn't really going to buy, just look. I realise I could've got it online cheaper, but as they had the SPVA panels, I didn't mind paying the extra to get the panel I wanted first time. It actually fitted in the back of a Punto with room to spare!
MrMav11
God I hope mine is a S-PVA then now, wouldnt have had a clue otherwise. is it that much of a difference? was is the differnece? better blacks or somehing?
why did you pick the R88/R87 then? as in currys and stuff they have the R74 going cheap or did you wamt a next gen LCD TV thats why I did, for a little extra a new model TV?
Have you tried Movie Plus? does it make it smoother? no motion blur etc on a normal DVD fast action movie?
Any pics you can post?
c.jelly
Established Member
I don't think there's been any reports on here of the 40"ers with a different sticker on the back. :rotfl:
MrMav11
well its here (and the stand) all it says on the back is LE40R87BD (R) then a lot of spaces and then a S is that good or bad? what have I got?
MrMav11
andyloc,
You have Samsung S-PVA panel.
Cool!! I think/hope! its seems the best , its stunning either way though! am well pleased so far with it. Pictures no matter where from look great. Theres so many options though for picture settings I need to know about.
cheers
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
