Just bought the AE EVO3b set, connecting to Amp...
Discussion in 'Home Cinema Speakers' started by pez, Sep 2, 2004.
  1. pez
    pez
    May 1, 2004
    776
    Newport
    +27
    Howdy, im still pretty amazed that i found the speakers in a local shop going for the same price as the best price i found on the net, i bought them and brought them home.
    now im waiting for another local retailer to get his hands on a Yamaha ax750 amp for me, but in the meantime i was wondering whether i could run the floor standers from my old technics stereo integrated amplifier SU-Z100 amp (this thing is so old it runs on steam).
    the current (20 year old) speakers that are connected up to that amp are SB-3410s that are described on the back as;
    Input: 100W, Music:50W DIN
    Impedance 8ohm
    so my question is, can i just go ahead and connect the wires to these new speakers to give them a listen?
    what are the numbers that i need to keep an eye on when plugging amps into speakers?
    does power handling on a speaker mean the max wattage amp that you can connect to it (evo3s are 150w fronts), so you couldnt link up a 100w speaker to a 150w amp?
    where does impedance come into all of this (evo3s are 8ohms just like my technics speakers).
    not completely lost, i know which country im in!
    cheers for any help in advance.
    pez
  2. tom_nieto
    tom_nieto
    May 21, 2003
    427
    Brighton
    You should be fine :)
