Just bought Pronto- help
Discussion in 'Home Cinema Control & Remote Controls' started by fabryuk, Mar 31, 2002.
  1. fabryuk
    fabryuk
    Hi, at last bought myself a pronto as Easter present. Still have not master all the learning function yet. I am not sure whether I understand the manual completely. Do you have to learn each key in each remote control? Or can you learn all the keys at once, please help the manual is not very clear on this, or am I too thick ??
  2. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    goto www.remotecentral.com
    and download pronto edit then either look for a complete ccf from the thousands there hoping to find one with same kit as you or just download the device ccf for your equipment.
  3. fabryuk
    fabryuk
    Thanks, at first I thought ccf file is only for design of the button, did not realise that somebody has learn all the keys!!
