Just bought portable dvd player. Could I attach a usa hard drive to it ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by jamieuk23, Sep 12, 2005.
  1. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,173
    +26
    Hi I have just bought the SHINCO SDP-1250 portable player.
    I noticed on the specs it says it has a USB port. just wonderd if I could attach a usb hard drive to it and play my divx/DVD`s fromt he hardd drive ??
    your thoughts please ?
    here is specs....http://www.allcam.biz/products/sdp-1250.html
    Key Features
    Play back format; DVD, DivX, XviD, VCD, SVCD, MP3, DVD-R/RW, DVD+R/RW, CD, CD-R, CD-RW, JPEG, Kodak Picture CD
    Built-in card reader: support SD, MMC, and Sony memory stick
    Support playback MP3 and MP4 (DivX, Xvid) burned on DVD-R / DVD+R
    USB OTG technology built-in, directly read pendrive (thumb drive, U-disk)
    Superior picture and sound quality
    High capacity rechargeable Li-ion battery (2.5 hr)
    Built-in anti-shock system
    Multi-region out of the box, buy your DVD from any country
    S-video out and Composite video out
    Progressive scan
    Picture Quality
    10.2" Color TFT LCD screen, also double as monitor for GPS, digital camera
    High contrast, high resolution, and high brightness TFT LCD display: 370:1 , 400 nit (typical), 800 x 3 x 480 = 1152000 dots
    S-Video output
    Composite Video Output
    Sound
    Dolby Digital Sound Output
    HDCD Decoder
    Optical Digital Audio Output
    Stereo Audio Output
    Jacks / Ports
    1 x SD/ MMC / MS slot
    1 x USB port
    1 x DC in (9 V, 2.5 A)
    1 x Composite audio out / in / Optical out
    1 x Composite video out /in
    1 x S-Video out
    1 x Component video out / progressive scan out
    2 x Stereo headphone,
    Additional Features
    Multi-Angle Capability
    Multi-region (region free) out of the box, plays DVD from any country
    Multi-Aspect Ratio Capability : 4:3, 4:3 Letterbox, 16:9
    Zoom Play (2X/4X)
    Fast Forward/Reverse Play (2X/4X/6X/8X)
    Slow Forward/Reverse Play (2X/4X/8X)
    Frame By Frame Play
    Search Play
    Programmable Play
    Shuffle Play
    Repeat Play (Title, Chapter, All, A/B)
    Still Frame
    Intellectual Upgrade Function
    Auto Power Off
    Screen Saver/Power Saving Function
    Hi-fi Stereo Headphone Output
    Built-in Anti-Shock System
    Built-in Stereo Speakers
    Dimensions: 257 x 168 x32 mm (without battery)
    Weight: 1200 g (without battery)
    Accessories Included
    Multifunction Remote Control
    Auto switching AC Adapter (110 -240 V)
    High Capacity Rechargeable Lithium Battery (2.5 hours)
    Car Adapter
    Video Cables: S-Video cable, component video cable, and composite video cable
    Stereo audio Cable
    Specifications
    LASER WAVELENGTH 650nm/780nm
    VIDEO SYSTEM PAL/AUTO/NTSC
    FREQUENCY RESPONSE 20Hz~20KHz±1dB
    S/N RATIO =95dB
    AUDIO DISTORTION+NOISE =-80dB(1KHz)
    CHANNEL SEPARATION =85dB(1KHz)
    DYNAMIC RANGE =85dB(1KHz)
    OUTPUT AUDIO OUTPUT
    (ANALOG AUDIO) output level:2V±10%
    load impedance:=10KO
    VIDEO OUTPUT output level:1Vp-p±20%
    load impedance:75O
    POWER SUPPLY DC 9V 2A
    Allowable motion temperature 5-35 degree C
    POWER CONSUMPTION =20W
  2. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    At The Track or Melbourne Victoria Australia
    +3
    No
