Just bought Plasma - need DVD Recorder!
Discussion in 'Blu-ray & DVD Players & Recorders' started by theoldbill, Aug 19, 2004.
  1. theoldbill
    theoldbill
    Dec 27, 2003
    40
    Manchester
    +6
    I've had several models recommended to me by retailers, probably the favourite at the moment is the JVC DMR10 but it doesn't fulfil all of my requirements.
    I need:
    Firewire input
    Progressive Scan
    Component Outputs
    RGB in (for Sky Box)
    Any suggestions?
    I was thinking about the Panasonic range but I read on here that they have slow response times which REALLY annoys me! But I've not really demo'd anything yet.
    Sound and Vision recommended the JVC but I don't think it has RGB input for the Sky - will it make that much difference if it's just S Vid?
    Budget about £300 but pretty flexible.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,197
    Argyll
    +2,257
    As you observe the JVC lacks RGB Input so I would avoid unless you quite tight on your budget.
    The Panasonic E65 meets all those requirements for a little over £300. Highly recommended.
    Have you considered a HDD/DVDR combo: the Toshiba RDXS32 also meets all your requirements for around £400 and offers great features and functionality. See the review thread here.
  3. theoldbill
    theoldbill
    Dec 27, 2003
    40
    Manchester
    +6
    Thanks a lot, I'll give both of them some consideration.
    Just need to convince the missus now......
    I'm sure my body could function on just one kidney couldn't it?
