Chris The Ninja
Established Member
I currently have a very poor CRT and use, if not the cheapest cables Cable Universe had to offer, certainly not 'quality' ones. I have just invested in a new 42" plasma TV which is currently on order so I am thinking of buying some new cables and just looking for some suggestions.
I have Homechoice as my main TV source, using the silver box for those that know, and it is not a particularly high quality source but does output RGB SCART. So I need a new RGB SCART (~ 1m) but it doesn't need to be amazing.
I will also be connecting the TV via coax to use the internal Freeview service and I can see some value in spending a modest amount on this. Will probably need at least 1.5m long. The plate on my wall is male but don't know what the fitting is on the TV yet (assume female?).
I want to connect my laptop (VGA/DSUB), which will probably require a 3m cable.
I also have a DVD player which I want to connect using component (~ 1m).
I will also need an RCA phono cable to connect from the TV to my amp (~ 1m).
Have had a look on Cable Universe but the selection for coax and SCART isn't that inspiring. Also had a look on tvcables which looks more like the thing. Don't want to spend a fortune, natch, but just want some cables that will get the best of the equipment I have.
