Just bought a TV, how long do I keep the box?
Discussion in 'TVs' started by Fordy, Nov 19, 2003.
  1. Fordy
    Fordy
    Jul 9, 2003
    1,537
    41
    Liverpool
    +24
    the box my 32" JVC came in is Huge. How long do I have to keep it to reasonably cover myself in case of a breakdown and or it needs returning?:confused:
  2. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    I keep all my boxes indefinately. Useful if I move or sell on the equipment. Most are in the loft. Some above the roof timbers in the garage.
    Big tv boxes can be opened up at the bottom, then the box can be 'folded' (after removing the polystyrene and bag, to be stored elsewhere).
    I'd suggest keeping it at least 60 days.
  3. Fordy
    Fordy
    Jul 9, 2003
    1,537
    41
    Liverpool
    +24
    But i Could sell this box for £150k on the property market its that big, plus i dont have a garage or a reasonable loft area.
  4. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    What about under a bed, behind the sofa, behind a wardrobe?
  5. Fordy
    Fordy
    Jul 9, 2003
    1,537
    41
    Liverpool
    +24
    not much room all round to be honest
  6. Pug72
    Pug72
    May 10, 2003
    1,986
    Hereford
    +275
    My 36inch tv's box was so big it woulodn't fit through the door.
    I had to remove the patio door round the back to get it in!
    As didn't like the tv I arranged for it to be collected, but the earliest they could come was 2 weeks.
    So I had this huge box stuck in the lounge for 2 weeks!!!!
    I suggest if you like the set and are keeping it, then you can destroy/bin it.
    If the tv develops a fault, the packaging will not be a requisit when/if it has to be returned.
  7. Fordy
    Fordy
    Jul 9, 2003
    1,537
    41
    Liverpool
    +24
    I'm pretty sure in the terms and conditions state packaging must be complete and intact in instance of return or words to that effect.
    Ill give it a month then dispose. thanks guys
  8. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    actually you do need to retain all packaging as in the event of a fault. as i found out when my 36" tv went down had hell swapping over and the best part is that sony dont sell or make extra boxes
  9. Tel boy
    Tel boy
    Apr 2, 2001
    147
    UK-North East
    +5
    In that case why don’t you put some roofing felt on the top of the box & paint the sides green & put it in your garden…..** Hey Presto **…. an instant garden shed :smashin:
    Using the above method would serve 2 purposes:
    1. It gets rid of the box without actually getting rid of the box!
    2. You can use the "Shed" in future to store boxes from other electrical items indefinitely as Simon 1 advised.
    Regards, Tb :D :D
  10. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,896
    71
    50 Rue St Georges, Paris.
    +27
    If your TV was bought mail order it will be a good idea to keep the packaging whilst covered by supplier's guarantee, probably twelve months.
    Flatten the cardboard and keep with the polystyrene so that if needing service it can be re-assembled and strapped together for safe transport.
    This is recently more important because a lot of mail order dealers relied on Endeva to provide service support, since they went into receivership they only work now for Box Clever.
    This means a return to supplier for service as local dealers won't help you until it's out of warranty, then they can charge you properly, in warranty service rates are very poor so most won't touch it whilst under guarantee.
    Best to keep the packaging and insist on a replacement TV if you have problems. :cool:
  11. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    Couldn't agree more.
    It's far easier to get a replacement from the vendor, if you do have the box.
    And if your set did require fixing outside the home - would you want it rattling about in the back of some van, poorly protected or in it's original box/packing?
  12. Time's Up
    Time's Up
    If the box won't fit in your house, I'm guessing that your TV is too big for the room it's in!:laugh:
  13. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,896
    71
    +27
    No such thing as a TV that's too big ! :D
  14. Gillious
    Gillious
    Oct 28, 2003
    45
    should see the box for my 42" RPTV... I thought I was going to have to knock my front wall down to get it in.
    It's now sitting in my 6x6ft shed taking up ALL the space almost.
    Think i'll go flat pack it tomorrow if i'm feeling brave enough.
  15. twarde
    twarde
    Oct 11, 2002
    147
    2
    +13
    If you've got young kids, its the best toy ever. They will play for hours with a big TV box - well mine did any. A very cheap toy!
  16. aaronjon
    aaronjon
    yes a roll of tape and a cardboard box = a cheap enjoyable afternoon for the kids (not the polystyrene though thats a no no).
    imho
    most high street retailers suggest 14 days, as they offer some type of no quibble return, after which time it falls into the guarantee, which is repair or exchange, so depending on the suppliers policy of who does the repair, will dictate the length of time you keep the box.
