Just bought a subwoofer
Discussion in 'Subwoofers' started by Brox, May 11, 2002.
  1. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    I've just bought a Kef 30b sub for £200 fro Hyperfi, wasn't able to get a good demo in the shop so I risked it based on What hi fi review and the fact that I needed somthing small and didn't want to pay £500 for q150e.
    However i'm a little underwhelmed at the moment, I don't seem to be getting much out of it. Do I need to run it in like conventional speakers and should I set the crossover frequency at its lowest point (I have 601's) and how do youdecide whst the volume should be.
    Also if I use just the one phono lead is it as good as a 1 to 2 cable
    Hope someone can shed light.
  2. PHY.com
    PHY.com
    subwoofers need to be run in just like any other speaker. Set the crossover to it's highest point and let the amp handle the bass management.
    set the volume on the sub to about half and then use the amp to increase or decrease bass further. When you can hear the subwoofer turn the volume down a bit until you can no longer hear it.
  3. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    Thanks, do think things will improve quite a bit after a run in?
    Does anyone else have this sub who can tell me what I should expect.
    I was expecting it to be a big step up from my Yamaha sw80 but so far it is not the case.
  4. Chip
    Chip
    A friend of mine bought this sub some years ago and paid a lot more than you did. Its a good little sub. Better than Canadian makes.
    Chip
  5. stranger
    stranger
    brox, i refused a deal to swap one of my yamaha sw80s for the kef a while back. get your money back and get a paradigm pdr10 or even two chip is obsessed with his dislike of paradigm imo.
  6. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    I did look at the Paradigm's but to be honest to me they look
    cheap. and I didn't want it sat next to my lovely expensive apollo
    AV stand - i'm a bit picky like that probably to my disadvantage. The
    kef does look good though - I hope it will sound better with time &
    running in
  7. Chip
    Chip
    Top man Brox :D
    Chip
  8. John Watts
    John Watts
    Jan 27, 2001
    3,961
    71
    Leeds
    +80
    What is your problem with Paradigm chip? come on mate shed some light on your hatred of this company.
  9. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    I actually meant the 20b not the 30b, can anyone who has had one tell me how long its takes to 'run in'.
