Just bought a Sky+ box ....
Discussion in 'Sky Digital TV Forum' started by RMCF, Apr 16, 2005.
  1. RMCF
    RMCF
    Aug 24, 2000
    7,406
    +735
    from eBay. I already have Sky Digital installed. What do I need now? Is it a MUST to have a quad LNB? Any help appreciated.
  2. Boy Lex
    Boy Lex
    A quad LNB would be a good idea if you want to make use of the recording features. However you should still be able to record what you are watching and do live pause - rewind with just the single lnb.
    If you do want to get hold of a quad - they are quite cheap on ebay and you can replace the LNB on your existing dish quite easily. A trip to maplins will get you another sat cable run and some f-connectors for the second feed to the box (to allow you to record 1 channel while watching another). Invariably the trickiest part is finding enough of a hole to get the cable into your living room.
