Just bought a Panny TH-42PA50 - I need tips & advices
Discussion in 'Plasma TVs' started by Benfica, Jul 22, 2005.
  1. Benfica
    Benfica
    I just bought a TH-42PA50 plasma from panasonic.
    What tips & advices can you give me, regarding callibration, normal usage, burn-out prevention, and so on.
    Thanks & best regards
  2. mlinhares
    mlinhares
    Jul 1, 2001
    354
    Portugal
    Use cinema mode, avoid still images (like games) and films with "black bars", at least in the first 200 hours.
    Just a question. Are you happy with the black levels? In my 37PA50 and in cinema mode the blacks aren't CRT like… in fact they are far from it.
    Boas visualizações.
  3. Benfica
    Benfica
    When you say films with black bars, do you mean:
    1) 4:3 pictures with black bars on left & right ?
    2) 1.85 AR films with black bars on top and bottom ?
    Well, I just started to see films with 2).
    Regarding your question, yes, I'm happy with the black levels.
    What I did: Selected "Normal Mode" and callibrated "brightness", "contrast", "sharpness" and "color" using DVE (Digital Video Essentials) DVD. For use with the DVD Player, I turned off all options like MPEG NR, Colour Management, etc. I'm using a Pioneer DV-575A, in progressive scan mode.
    HTH
