just bought a Hitachi 42PD9700 42" Plasma TV
Discussion in 'Plasma TVs Forum' started by daxy1, Apr 23, 2007.
  1. daxy1
    daxy1
    Apr 22, 2007
    146
    hi ive just bought a Hitachi 42PD9700 42" Plasma TV it's the first plasma i have owned it is on order from john lewis i paid £975 with the 5 year cover can any one tell me if it will play the xbox 360 well enough on it and is the pip a fixed picture or does it give off a see through picture thanks daxy1
  2. AndyLFC5
    AndyLFC5
    Jan 20, 2007
    760
    +30
    I have this set and 360, not sure, but I wouldn't try it, reading through the manual, it refers to PIP as possible reason for screen burn, and especially as yours is fresh out the box I would avoid.
  3. jonspurs
    jonspurs
    Dec 13, 2005
    723
    +44
    It gives a fixed picture - left and right. Or, one main one on the left, and 3 on the right side. It's all explained in the manual.
    Jon
  4. daxy1
    daxy1
    Apr 22, 2007
    146
    cheers lads thanks for the info i cant wait for the tv to arrive i think i will leave the 360 off for a bit i will give it a month to settle down
  5. SPRINGERS
    SPRINGERS
    Mar 25, 2005
    434
    43
    Braintree
    +135
    Congratulations the Hitachi is a great set, my son plays his Xbox 360 on it all the time and no retention problems at all. The PIP function is good fun you can play the Xbox on one side of the screen and have TV on the other side, you can use the remote to swap audio to whichever source that you want!:smashin:
  6. wgg
    wgg
    Mar 31, 2007
    16
    3
    I also bought my PD9700 from John Lewis on Friday. Absolutely delighted
    They also did a price match with Sound and Vision which brought it down to approx. £880
  7. daxy1
    daxy1
    Apr 22, 2007
    146
    well begger me i didnt get a price match so never mind too late now did they tell you when to expect delivery
  8. Accylad
    Accylad
    Nov 28, 2005
    7,117
    Accrington
    +320
  9. trickytree123
    trickytree123
    I'd recommend you set the Xbox 360 to 1080i output, and change the TV setting to 'Full 2' (press the aspect ratio button on the bottom row, then press right on the direction pad until Full 2 is selected).
    This will be the best match between your 360 and TV (and any other 1080 source - Sky HD, HD-DVD, PS3/Blu Ray etc.)
  10. daxy1
    daxy1
    Apr 22, 2007
    146
  11. wgg
    wgg
    Mar 31, 2007
    16
    3
    An update since having the beast for over a week now.
    I thought long and hard about what to get and have to say that the SD quality is very good, Sky HD is tremendous and the sound is pretty good, although will probably fit something at a later date.
    Overall very impressed and have had no issues at all such as high pitched whining:thumbsup:
  12. tingull
    tingull
    Nice to see people getting on well with the PD9700's, mines been fine allso
    no wistle and picture is good on sd and hd, and gotto comment the sound is really good, wasn't expecting it to be so good really was suprised. My tv was on for over 24 hours the other day, as i fell asleep watching discoveryHD at night and no problem at all with it, just do a screen wipe now and again cause of the dreaded channel markers in the corners, was dubious about buying it at first with the bad psu faults and contrast shift problems but i have been well impressed so far.
    Thx tingull :)
  13. sjbrownhome
    sjbrownhome
    What is the "Full 2" setting ?
