Just been offerd Pioneer PDP435xde ????
Discussion in 'Plasma TVs' started by splnter, Jul 28, 2005.
  1. splnter
    splnter
    Oct 20, 2003
    531
    Basingstoke. Hampshire
    +27
    Ok ive been looking around to get one,
    Went into a shop and they said they have an x dem 1 .. £2650. :eek:
    So i told them i can get it new for £2399, then they said we will give you the stand too !!! well i went away then about 10 mins later they phoned me .. said i could have it for £2500.
    I then said but i can still get it new cheaper !!!!
    Went away again... 5 mins later they phoned again... You can have it for £2300... Its 2 months old not a mark on it. 2 years warrenty and its from audio t... Well what do you think go for it or leave it ???
    Thanks.
  2. dvdchild
    dvdchild
    Aug 10, 2004
    4,500
    +137
    if you can afford it then take it - when i last looked cheapest i could get it for was £2700 with stand.
  3. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,115
    63
    Andover
    +109
    I get a pdp435xde with wall mount from buyyourav.com - brand new - for 2.5k. I'd check for the amount hours and then deceide.
  4. Alan A
    Alan A
    Jul 7, 2004
    186
    16
    What are Buy your Av com like?
    I had a look at their site and the prices looked interesting
  5. Alan A
    Alan A
    Jul 7, 2004
    186
    16
  6. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,115
    63
    Andover
    +109
    good service, very down to earth and no bull from them. Also a "the works" dealer which helps with warranty
  7. splnter
    splnter
    Oct 20, 2003
    531
    +27
    Hi, Ok i went and bought it. £2300.
    Just got to set it up now. :)
    Ok all done.
    [​IMG]
    And i done the good thing and gave my father my old sony 32 fx60. :)
