Just answer the question without any Sarcasm PLZ
Discussion in 'Movie Forum' started by parekhk, Aug 21, 2003.
  1. parekhk
    parekhk
    Jan 14, 2003
    168
    Do Laser Disk work on DVD player? :suicide:
  2. mcmullanbrush
    mcmullanbrush
    Apr 20, 2002
    1,137
    39
    rotherham
    A laserdisc would not fit into a DVD player as it measures 12inches across. If you mean compact disc then the answer is yes, it will play on a DVD player.
  3. WBC
    WBC
    Is that a wind-up????
  4. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    Over the Hill & Far Away
    +135
    Unless you own one of the pioneer combi LD players.. which play laserdisc and dvd!
    Matt
  5. Garrett
    Garrett
    Apr 21, 2001
    39,808
    2
    167
    The best thief you’ll never see.
    +6,502
    Even if they did fit in a DVD player I would still think it would be incompatible. Remember the big playas in DVD where coming out with different formats of DVD but they got together in the end to come up with a compromise.
  6. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    Despite the information being held in a digital type format, the signal is infact coded in an analogue way, which makes DVD and LaserDisc incompatible. Unless as noted before you have one of the "combi" LD/DVD units on the market. The two technologies are so different it is much akin to combining a record deck and a cd player in one.
  7. parekhk
    parekhk
    Jan 14, 2003
    168
    Truth is I forgot about the size of laser disk.
    As someone was sell some, I asked b4 thinking..........
